Revit API
Member
Message 1 of 4 (148 Views)
Unable to get material using "Materials.Contains(name)"
148 Views, 3 Replies
10-16-2012 02:08 AM
I'm using Revit 2013. I want to get the material from a family document (e.g.
Material m = m_familyDocument.Settings.Materials.get_Item(name);). I used 2 different functions (Materials.Contains(string name) and Materials.get_Item(string name)) but both also giving me the following error: "Revit encountered a System.MissingMethodException: Method not found: 'Autodesk.Revit.DB.Materials Autodesk.Revit.DB.Settings.get_Materials()'." Am I allowed to retrieve material from a family document? What is the correct function to be used?
Chiou Hau
Valued Contributor
Message 2 of 4 (145 Views)
Re: Unable to get material using "Materials.Contains(name)"
10-16-2012 02:24 AM in reply to: chiouhau
Dear chiouhau,
may it be that - when compiling - you have linked to the 2012 RevitAPI.dll while running the addin in Revit 2013 ?
I've noticed in another posting that you code for both 12 and 13, so maybe you use a 2012 method that is already deprecated in 2013 ?
Cheers,
Revitalizer
Member
Message 3 of 4 (140 Views)
10-16-2012 02:54 AM in reply to: Revitalizer
You are right. So is that means we must use different version of RevitAPI.dll if we want to run addin in different Revit version?
May I know what is the correct function used to get the material from family document if I only have the name? Thanks.
Valued Contributor
Message 4 of 4 (136 Views)
10-16-2012 03:01 AM in reply to: chiouhau
here is more information about running code both with 2012 and 2013:
http://thebuildingcoder.typepad.com/blog/2012/07/multi-version-add-in.html
If you compile your code, you can see it in the compiler warnings which methods may disappear in following Revit API versions.
To answer the other question, getting materials by name from a family document: another one may give you more infos, I've no time...
Bye,
Revitalizer
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
