I'm writing a console application in C#.net and I was hoping to access the Revit API's by including them as references. I can code OK (all the autocorrect works and finds the contents of the libraries), but when I run the code, it crashes saying I have a x86 or x64 issue. I found other pages showing how to resolve this, but nothing seems to work for me (in either 32- or 64-bit configurations )
But my question isn't really how to resolve that, but rather why am I getting this error? I'm working with all 64-bit API's, so why is there any issue? I would think that referencing a 64-bit Revit API on a 64-bit console application would be compatible.
So, can I even access the Revit COM from a console application?
And, if I can access Revit, how can I get rid of this x64 x86 issue?
Can you please give more information on the actual issue? i.e., is there an error message or exception message?
Revit does not have a COM API anymore so I am not sure how you are using the Revit API in an external application.
More details about the what you are doing with the API would help.
Best Regards
Gopinath
I guess if there is no COM API, then that resolves the issue. Any reasons why they don't have COM access? Seems like a terrible lack of functionality.
Just to confirm, something like this isn't possible:
Autodesk.Revit.ApplicationServices.Application RevitApp; RevitApp = (Autodesk.Revit.ApplicationServices.Application)Marshal.GetActiveObject("REVIT.Application");
I'm using 4.0 .net.
There was a COM based API for Revit many releases ago but we do not have one anymore. The supported API is a .NET API and it has to run in-process inside Revit. If you could describe what you are trying to achive, I may be able to suggest some alternatives.
Best Regards
Gopinath
There isn't much to say, since if you say COM access is impossible, then I don't have any recourse. I'm trying to create a C# console Application. That won't work without COM access.
Strange, I can access CATIA and Rhino without issue. This is a bummer that Revit isn't as useful in this sense. I'd much rather code my stuff in a simple-to-use EXE, rather than have my clients try and install the crappy addin stuff into their session of Revit.
Moving forward, I'll just have to recompile my code as a Revit plug-in, and access CATIA and Rhino via COM from Revit. I assume that is doable.
