HI, I am new in revit api
I have a sheet with a titleblock family
Family have shared parameters
i want to write a vb.net procedure that read the value of parameters. Where I can find a sample?
thanks
Solved by scarta. Go to Solution.
Solved by Joe.Ye. Go to Solution.
Hi Scarta,
You can use the shared paramter name to get the parameter , then read the parameter value.
Here is the code snippet to show how to read the shared parameter value from the title block.
<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _ Public Class RevitCommand2 Implements IExternalCommand Public Function Execute(commandData As ExternalCommandData, ByRef messages As String, elements As ElementSet) As Result Dim app As UIApplication = commandData.Application Dim doc As Document = app.ActiveUIDocument.Document Dim sel As Selection = app.ActiveUIDocument.Selection Dim ref1 As Reference = sel.PickObject(ObjectType.Element, "Please pick title block") Dim tb As FamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance) '''title block is a FamilyInstance If tb Is Nothing Then Return Result.Failed End If 'If the target shared parameter is from the family symbol/ family type. Dim param2 As Parameter = tb.get_Parameter("SharedParameterName") 'If the target shared parameter is from the family instance. 'Parameter param = tb.get_Parameter("SharedParameterName"); //directly use the shared parameter name 'show the fire rating in task dialog TaskDialog.Show("target shared parameter value", param2.AsString()) Return Result.Succeeded End Function End Class
i receive an error on the line tb.get_parameter the vb editor say "is not a member of autodesk.revit.db.familyistance"
any idea?
Sorry, I used the code converter to convert the C# to VB.net. The code was not converted completely correct.
Here is the one should work.
<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _ Public Class RevitCommand2 Implements IExternalCommand Public Function Execute(commandData As ExternalCommandData, ByRef messages As String, elements As ElementSet) As Result Dim app As UIApplication = commandData.Application Dim doc As Document = app.ActiveUIDocument.Document Dim sel As Selection = app.ActiveUIDocument.Selection Dim ref1 As Reference = sel.PickObject(ObjectType.Element, "Please pick title block") Dim tb As FamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance) '''title block is a FamilyInstance If tb Is Nothing Then Return Result.Failed End If 'If the target shared parameter is from the family symbol/ family type. Dim param2 As Parameter = tb.Parameter("SharedParameterName") 'If the target shared parameter is from the family instance. 'Parameter param = tb.Parameter("SharedParameterName"); //directly use the shared parameter name 'show the fire rating in task dialog TaskDialog.Show("target shared parameter value", param2.AsString()) Return Result.Succeeded End Function End Class
HI...
I have a problem with this line:
vb editor say "Can not use Parameter as expression" and param is not declared
Hi Scarta,
Please remove the get_ from below line.
VB.NET doesn't need the get_ for when calling the class get properties.
hi,
I have removed the _get but the problem is Parameter param, the error is: "Parameter is a type that can not be use as espression"
I post he total code:
Region
"Imports"
' Import the following name spaces in the project properties/references.
' Note: VB.NET has a slighly different way of recognizing name spaces than C#.
' if you explicitely set them in each .vb file, you will need to specify full name spaces.
'Imports System
'Imports Autodesk.Revit.DB
'Imports Autodesk.Revit.UI
'Imports Autodesk.Revit.ApplicationServices ' Application class
'Imports Autodesk.Revit.Attributes ' specific this if you want to save typing for attributes. e.g.,
'Imports Autodesk.Revit.UI.Selection ' for selection
Imports
Revit.Util.Constant
Imports
Revit.Util
Imports
System.Reflection
#End
Region
#Region
"Description"
' Revit Intro Lab - 2
' In this lab, you will learn how an element is represended in Revit.
' Disclaimer: minimum error checking to focus on the main topic.
#End
Region
'<Autodesk.Revit.Attributes.Regeneration(Attributes.RegenerationOption.Manual)>
'<Autodesk.Revit.Attributes.Transaction(Attributes.TransactionMode.Manual)>_
'<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
Transaction(TransactionMode.Automatic)> _
Public
ClassRevitCommand2ImplementsIExternalCommand
PublicFunctionExecute(commandDataAsExternalCommandData, ByRefmessagesAsString, elementsAsElementSet) AsResult_
ImplementsIExternalCommand.ExecuteDimappAsUIApplication = commandData.ApplicationDimdocAsDocument = app.ActiveUIDocument.DocumentDimselAsSelection = app.ActiveUIDocument.SelectionDimref1AsReference = sel.PickObject(ObjectType.Element, "Please pick title block")
DimtbAsFamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance)
IftbIsNothingThenReturnResult.FailedEndIf
'If the target shared parameter is from the family symbol/ family type.DimSh_NameAsParameter = tb.Parameter(BuiltInParameter.SHEET_NAME)
DimSh_NumberAsParameter = tb.Parameter(BuiltInParameter.SHEET_NUMBER)
DimSh_ScaleAsParameter = tb.Parameter(BuiltInParameter.SHEET_SCALE)
DimparamAsParameter
'Dim param2 As Parameter = tb.Parameter("D2")'If the target shared parameter is from the family instance.Parameterparam = tb.Parameter("D2") '//directly use the shared parameter name
'show the fire rating in task dialog'TaskDialog.Show("target shared parameter value", param2.AsString())ReturnResult.Succeeded
End
Class
hI..with this procedure i can retrieve built in parameter but when I check value for shared parameter i retrieve "nothing"
I have used bitchecker with the title block, but I not retrieved any shared parameter...
please download rvt file from http://www.fxcrender.com/download/u17.zip
this is the code: and i upload the rvt file
#Region "Imports" ' Import the following name spaces in the project properties/references. ' Note: VB.NET has a slighly different way of recognizing name spaces than C#. ' if you explicitely set them in each .vb file, you will need to specify full name spaces. 'Imports System 'Imports Autodesk.Revit.DB 'Imports Autodesk.Revit.UI 'Imports Autodesk.Revit.ApplicationServices ' Application class 'Imports Autodesk.Revit.Attributes ' specific this if you want to save typing for attributes. e.g., 'Imports Autodesk.Revit.UI.Selection ' for selection Imports Revit.Util.Constant Imports Revit.Util Imports System.Reflection #End Region #Region "Description" ' Revit Intro Lab - 2 ' ' In this lab, you will learn how an element is represended in Revit. ' Disclaimer: minimum error checking to focus on the main topic. ' #End Region '<Autodesk.Revit.Attributes.Regeneration(Attributes.RegenerationOption.Manual)> '<Autodesk.Revit.Attributes.Transaction(Attributes.TransactionMode.Manual)>_ '<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _ <Transaction(TransactionMode.Automatic)> _ Public Class RevitCommand2 Implements IExternalCommand Public Function Execute(commandData As ExternalCommandData, ByRef messages As String, elements As ElementSet) As Result _ Implements IExternalCommand.Execute Dim app As UIApplication = commandData.Application Dim doc As Document = app.ActiveUIDocument.Document Dim sel As Selection = app.ActiveUIDocument.Selection Dim ref1 As Reference = sel.PickObject(ObjectType.Element, "Please pick title block") Dim tb As FamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance) 'title block is a FamilyInstance If tb Is Nothing Then Return Result.Failed End If 'If the target shared parameter is from the family symbol/ family type. Dim Sh_Name As Parameter = tb.Parameter(BuiltInParameter.SHEET_NAME) 'Dim Sh_Number As Parameter = tb.Parameter(BuiltInParameter.SHEET_NUMBER) 'Dim Sh_Scale As Parameter = tb.Parameter(BuiltInParameter.SHEET_SCALE) 'Dim param2 As Parameter = tb.Parameter("D2") 'If the target shared parameter is from the family instance. 'D2 is a shared parameter Dim param As Parameter = tb.Symbol.Parameter("D2") '//directly use the shared parameter name 'show the fire rating in task dialog TaskDialog.Show("target shared parameter value", Sh_Name.AsString()) Return Result.Succeeded End Function End Class
Can anyone help me?
I have installed Bitchecker and Revitlookup for check parameters, but the shared paramed are not show
Hi..
Ihave resolved the problem....I was finding the shared parameter on the Title block family, but sp was on the SHEET family!!
Thanks for your help!!
Stefano
