Hello!
I used TableSectionData in my schedule:
TableSectionData tsd = colTableData.GetSectionData(SectionType.Header);
But, it allows to format cells only in header section. If i choose SectionType.Body it doesn't work.
In autodesk help(http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-76A3927E-6DA6-495F-A89C-00F760E3702C) I found:
Note: Adding rows and columns is only possible in the header section of a regular schedule.
Does anybody know can I work with Body section of the schedule? Or may be it will possible in Revit 2015.
Regards, Alexander.
I did a little research but could not find a lot of information. If you could let us know what it is you want to do with the body section of the schedule, I can try asking the engineering team.
Gopinath
