Dear All,
I need urgent help in finding a way to select elements in a revit model based on a given value of a shared parameter through Revit API. The next step is to assign some other shared parameter values to those selected elements. Any help will be highly regarded.
Thank You.
Atif
Dear Atif,
I am afraid that your query is too general for anyone to answer it as it stands now.
I can imagine that most people's reaction on reading this is that you maybe should employ a consultant to do the work for you.
People will certainly be more willing to jump in and help if you explain more clearly what you have already achieved and what your specific problem is.
Have you worked through the Revit API getting started material?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Based on that, have you implemented anything at all yourself yet?
There are a number of samples available online addressing everything that you are asking for.
I hope this clarifies, and please do not feel offended in any way by my questions and suggestions if this is already clear to you.
Thank you.
Best regards,
Jeremy
