Revit API
Message 1 of 2 (156 Views)
Ribbon Pannel Add In + Highlighting rooms
156 Views, 1 Replies
10-02-2012 12:35 AM
I am trying to make a external application using Ribbon Add In in Revit, Can anyone please tell me how to link the buttons of Ribbon Panel with database (sql/ Access) and how to highlight the rooms using their Room Id , using API ?
ADN Support Specialist
Message 2 of 2 (134 Views)
Re: Ribbon Pannel Add In + Highlighting rooms
10-10-2012 02:16 AM in reply to: mohammadarslan
You can write a Revit external command to access the database.
And bind the external command to your own button in the Ribbon panel.
If  the application to access the database is not related to Revit, you can start that executive application by starting a new process.
I hope you already know how to create a button in Revit Tab.
With regard to highlight a room,  I think the only way is to add the room to the selection. Revit highlight it.
Here is code fragment.
Selection sel = uiDoc.Selection.
sel.Elements.Add(room);
Hope this helps.
Joe Ye
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
