Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Ribbon Application
1 REPLY 1
gnikhil
308 Views, 1 Reply
Ribbon Application
Hi, I had just executed walkthrough : ribbon application available on autodesk website. Can some one help me, how we can execute the class of same assembly, which is loading the ribbon instead of providing another dll name in pushbutton constructure. e.g. PushButton pushButton1 = ribbonPanel.AddItem(new PushButtonData("HelloWorld1", "HelloWorld 1", @"C:\Practice\Autodesk\Revit\HelloWorld\HelloWorld\bin\Debug\HelloWorld.dll", "HelloWorld.Class1")) as PushButton; In above constructure i have provided the dll path having HelloWorld.Class1. If i have to use another class of same assembly, then how i can achieve this? Thanks Nikhil
Nikhil
1 REPLY 1
jeremytammik
in reply to: gnikhil
dear nikhil,
work through the 'my first revit plugin' and the DevTV tutorials available from the Revit Developer page, then you will reach complete illumination!
http://www.autodesk.com/developrevit
best regards
jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
The Building Coder
Rail Community
