Revit API
gg
Member
gg
Message 1 of 3 (147 Views)
RevitExtension AddIn 2013 conflicts with Own AddIn
147 Views, 2 Replies
09-02-2013 07:26 AM
I have created an AddIn for Revit (2012,2013, 2014) and I am using the OnIdling function that is accesable From the Revit API. The AddIn works great when i haven't installed the ReviExtension 2013 AddIn from Autodesk, but when I installed it, the function OnIdling wasn't thrown anymore. Since other people use this AddIn aswell I would like to find a solution to this problem. Is the RevitExtension 2013 AddIn blocking the Idling event?
Thanks in advance
Regards
GG
ADN Support Specialist
gopinath.taget
Message 2 of 3 (124 Views)
Re: RevitExtension AddIn 2013 conflicts with Own AddIn
09-03-2013 05:32 PM in reply to: gg
When you say RevitExtension 2013, I am assuming you mean Revit Extensions for Revit 2013 that you get as a part of Subscription Pack.
Please correct me if I am wrong. I did a bit of research and could not find any relevent information on the problem you mention. Do you see the problem go away if you uninstall Revit Extensions 2013? Do you see the same problem with Revit 2014 as well (or Revit 2012)?
Best Regards
Gopinath
gg
Member
gg
Message 3 of 3 (118 Views)
09-03-2013 11:22 PM in reply to: gopinath.taget
Thank you for your response. Your assumption is correct, I am talking about the Revit Extension fro Revit 2013.
I also did some research on this topic but could not find any matching topics on this problem. If I deactivate the .addin file, so that it won't be loaded at startup then my addin works fine. But if I activate the .addin files (form Revit Extension) then I can't acces the Idling event from my addin in Revit.
I have had the same problem with Revit 2012. I haven't tested it with Revit 2014, but I will try this later.
Regards
GG
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
