Hi
I'm creating a revity family. For the sake of simplicity lets say I'm creating a shape that has three dimensions A, B and C. These are locked to dimensions and can be set by the user in the normal way. Basically I would like to have another Yes/No parameter in the family which when set to yes would automatically make A = C, with C being greyed out and its value set to A's value.
Is this possible, or do I have to create two separate families?
Many thanks.
Solved by Scott_Wilson. Go to Solution.
Are you asking whether this is possible using the API?
If so, then it could be done in many ways, one possible way is to use an updater to detect changess to a family instance and manually enforce the parameter contraints as appropriate. This is likely not to be the most effiecinet way, just one quick example.
You could do this without using the API though, if you apply the dimension parameters to the geometry indirectly you can then use conditional statements in the parameter formulas to use or ignore individual parameters as needed.
For example if you had two dimension parameters, one simply called 'X' and another called 'Calculated X', then created similar for the other dimensions. You could then mkae a Yes/No parameter called 'Constrain X to Y' and then in the formula for 'Calculated X' put something like "if(Constrain X to Y,Y,X)". It does gets more complex when you want to mix and match the master / slave parameter combinations. Have fun.
