Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit DB Link with SQL Server
4 REPLIES 4
s_solt
5313 Views, 4 Replies
I have been trying the RevitDBLink plugin for Revit 2013 downloaded from the subscription resources. It doesn't appear to include any guidance nor can I find any online. These are my observations:
After installing it and starting Revit, The Add-ins menu now includes the item Revit DB Link greyed until a project is loaded
Click on this and it offers a dialog to select a new or recent database connection. There are tabs for Access 2000-2003, Access 2007 and ODBC.
I selected ODBC tab (intending to use SQL Server), and [Select a new Connection]
There are Export and Edit and Import buttons. I clicked Export and the standard Windows Select Data Source dialog appeared.
Because I wasn't logged on to WIndows 7 as Administrator, I couldn't create a Machine Data Source, so I chose a File Data Source and saved it as RDBLink.dsn
I selected the appropriate SQL Server, Integrated Security and didn't alter the default database.
When the the DB Link exported the project data to SQL two things happened:
1) Tables and foreign keys were created in the Master database - not intended
I had to clean up my master database using scripts generated like so:
SELECT 'ALTER TABLE ' + t.name + ' DROP CONSTRAINT ' + k.name FROM sys.foreign_keys k
INNER JOIN sys.tables t ON k.parent_object_id = t.object_id WHERE t.is_ms_shipped = 0
SELECT 'DROP TABLE ' + [Name] FROM sys.tables WHERE is_ms_shipped = 0
2) Truncation errors occurred where the exported data exceeded the size of the destination fields.
IMHO this is a bug in the Revit DB Link which may make it unsuitable for safe round trip (edit in DB and reimport to Revit) operations.
I only wanted to export from Revit so I tried again having
a) created an empty database RDBLink and selected it as default
b) unticked Use ANSI Nulls Paddings and Warnings
The import stilll produced errors; some tens of entries like this:
< DBG_WARN: for MEP topologies key, the optionId should be notInOptionId: line 96 of Elem\PlanTopologyIdInfo.cpp.
Again, since I wasn't interested in MEP I wasn't bothered anthough, again, this looks like a bug with the RDB Link.
I did get 251 tables of data from my Revit Project, including a table of Views with the following fields:
CREATE TABLE [dbo].[Views](
[Id] [int] NOT NULL,
[Family] [nvarchar](255) NULL,
[FamilyandType] [nvarchar](255) NULL,
[PhaseFilter] [int] NULL,
[PartsVisibility] [int] NULL,
[DetailLevel] [int] NULL,
[SunPath] [int] NULL,
[DisplayName] [nvarchar](255) NULL,
[SheetName] [nvarchar](255) NULL,
[SheetNumber] [nvarchar](255) NULL,
[Orientation] [int] NULL,
[AssociatedLevel] [nvarchar](255) NULL,
[Discipline] [int] NULL,
[DisplayModel] [int] NULL,
[ViewScale] [int] NULL,
[ScaleValue1:] [int] NULL,
[TitleonSheet] [nvarchar](255) NULL,
[ViewName] [nvarchar](255) NULL,
[Phase] [int] NULL,
[Sub-discapline] [nvarchar](255) NULL, --Mis spelling not mine!
From this I created a Query of Views:
SELECT TOP ( 100 ) PERCENT
    Id
   ,SheetName
   ,SheetNumber
   ,TitleonSheet
   ,ViewName
   ,'1:' + CAST([ScaleValue1:] AS NVARCHAR(5)) AS Scale
FROM
    dbo.Views
WHERE
   SheetNumber IS NOT NULL
ORDER BY
    SheetName
   ,SheetNumber
   ,ViewName
Quite a performance just to get this information. I'm going to try it doing it by using code and the api instead of the RDB Link but I hope the steps I have outlined help others to get Revit data into SQLServer.
Steve
Tags (4)
4 REPLIES 4
jeremytammik
in reply to: s_solt
Dear Steve,
Thank you very much for this helpful information. I am sure it will be much appreciated. To ensure you get full visibility for this, I would be happy to create a blog post on The Building Coder from it, if you like. Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
PGibson1969
in reply to: s_solt
Hi, I know this is one and a half years later, but I just did an ODBC export to SQL Server and encountered the same thing (tables created in master) that you did.  I used the queries you have below (copied and pasted into a new query, both statements) and the query executes correctly, but the tables dont dissappear.  What am I missing?  Did you use a command line interface for that?  I am using the new query in the Microsoft SQL Server Management Studio, and executing within there, so perhaps there is a step missing, but the tables stay there (screen shot below).  Thanks for any help you can provide!
Paul
s_solt
in reply to: PGibson1969
I will get back to you tomorrow. If. I don't then call my mobile 07747718389
Steve
Sent from my Sony Xperia™ smartphone
This message has been scanned for malware by Websense. www.websense.com
PGibson1969
in reply to: s_solt
Hey, I did a quick reply, but didn't see it post.  Basically I figured out that your queries just generate a list of SQL commands, so I redirected the results to a file and then used that file as a new query.  It worked, but the management studio tree view does not update correctly (even when refreshed) and so I could not tell it worked unitl I closed the tree and re-opened.  Thanks for your great post . . by the way, did you ever figure out how to get the export to create a new database, or to use one that you created for that purpose?
Rail Community
