Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit API - Access to Text & Label Types within Family and Projects
7 REPLIES 7
Message 1 of 8
mfleming.stantec
5014 Views, 7 Replies
I'm trying to add new text types and label types to a project or family.
I'm able to create new family types but I cannot access the text/label system paramters.
Revit 2013
Sorry for the noob question.
Tags (3)
7 REPLIES 7
Message 2 of 8
saikat
in reply to: mfleming.stantec
Hi
Does this post help: http://adndevblog.typepad.com/aec/2012/08/creating-new-textnotetype-programmatically.html
thanks
Saikat
Saikat Bhattacharya
Senior Manager - Technology Consulting
Message 3 of 8
Yes this will work.
I can look for the same procedure for labels and I'll be set.
Thanks!
Message 4 of 8
saikat
Glad the suggestion is helpful.
kinid regards
Saikat Bhattacharya
Message 5 of 8
mfleming.stantec
in reply to: saikat
For Text Types this worked.
Revit API - Create Text Type
For Label types I had to change "TextNote" to "TextElement" and "TextNoteType" to "Symbol".
Project completed.
Message 6 of 8
5674829
I want Create a new TextElement(Label) in a Family document via API,but i found i cannot! Because i did not find a method that is similar with Document.FamilyCreate.NewTextNote,Pipe.Create. How to Create TextElement(Label)? I am looking forward to hearing from you.
Message 7 of 8
arnostlobel
in reply to: 5674829
Dear 5674829:
I have not used this method myself, but I believe you could use the NewTextNote method in both kinds of documents, because it is a method of ItemFactoryBase, which is a subclass of both Creation.Document and Creation.FamilyItemFavctory. As far as I know, it has never been possible to directly instantiate a TextElement, because that class does not have a public constructor. Only TextNote object is possible to instantiate.
Cheers
Arnošt Löbel
Message 8 of 8
Thanks for this thread. It helped me to fix my own problem, for which i needed to understand how I could update the text font of text notes as well as labels.
Just for your information, a TextNote is a TextElement as well. The revit API docs says:
TextElement Class
Base class representing text elements in Revit.
...so when you filter for TextElements you will get Labels as well as TextNotes .
That said, the method that you so helpfully provided above, works for textnotes as well as labels:
@mfleming.stantec wrote:
For Label types (...) change "TextNote" to "TextElement" and "TextNoteType" to "Symbol".
So you actually don't need 2 methods but you can use 1 and the same method for both types.
Cheers
Rail Community
