Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revisions on sheet
7 REPLIES 7
Message 1 of 8
m.walk
1771 Views, 7 Replies
Revisions on sheet
Is there a way to access the revisions on sheet information in a viewsheet?  I can get the project revisions, but have not been able to find a way to access any information about the revisions shown on the revision schedule on a sheet.
There is an accessible revisions on sheet parameter however I cannot get anything meaningful out of it.   Has anyone had any luck with this?
7 REPLIES 7
Message 2 of 8
in reply to: m.walk
Sorry I don't have a solution, did you have any luck on this? I have 100 sheets and I need to add a revision to every one of them.
When I look at the "Revisions on sheet" parameter storage type it is set to None 😞
David
Message 3 of 8
saikat
Hi
The current API does not allow accessing this parameter and further working with it. However it is logged with the Development team to consider implementing in future.
Sorry for the bad news
cheers
Saikat Bhattacharya
Senior Manager - Technology Consulting
Message 4 of 8
timwinter
in reply to: saikat
Any movement on this?  It's a MAJOR sore point for our drafters and their carpal tunnel...
Message 5 of 8
in reply to: timwinter
I believe that this has been added in Revit 2014
See the ViewSheet.GetAllProjectRevisionIds & ViewSheet.GetAdditionalProjectRevisionIds, as well as the SetAdditionalProjectRevisionIds method.
The "additional" methods refer to revisions that have manually been added, while the "all" method also retrieves revisions that are due to revision clouds being visible in the view.
Message 6 of 8
Ning_Zhou
not quite understand that "additional" stuff? is that extra project revision added using API? seems i cannot add it using normal UI or perhaps i missed something?
from chm it defines as "the project revisions that are additionally included in the sheet's revision schedules", what does it mean?
looks like no relevant info. in sample SDK, will be great if someone can post short coding sample.
Message 7 of 8
in reply to: Ning_Zhou
The "additional" revisions are the ones that are manually placed on the sheet using the "Revisions On Sheet" window, that appears in the Properties tab for every sheet.
The revisions that are not "additional" are ones that are placed through the use of revision clouds.
Message 8 of 8
Ning_Zhou
thanks cshha for clarification.
looks like thses "additional" revisions are still the revisions added through normal Sheet Issues/Revisions window, just not yet instantiated w/ revision clouds by user.
not quite sure if it's useful? we're more concerned w/ numbering system which is too restrictive.
Autodesk DevCon in Munich May 28-29th
Rail Community
