Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Printsetup Papersize
1 REPLY 1
joostschlebaum
1028 Views, 1 Reply
I'm trying to create some sort of PDF printing app and it's working quite okay, except there is one issue. I cannot find how to change the PaperSize.
Example:
PrintManager pm = activeDoc.PrintManager;
                    pm.PrintSetup.CurrentPrintSetting.PrintParameters.PaperPlacement = PaperPlacementType.Center;
                    pm.PrintSetup.CurrentPrintSetting.PrintParameters.ZoomType = ZoomType.Zoom;
                    pm.PrintSetup.CurrentPrintSetting.PrintParameters.PaperSize = ????;
 How can I set my PaperSize? Is it possible to use an Equals string function?
Thank you in advance.
1 REPLY 1
Joe.Ye
in reply to: joostschlebaum
You can get all available paper size for the current PrintManager by PrintManager.PaperSizes. Then go through the collection of the returned PaperSize objects, find your target one.
Then assign the target PaperSize object to PaperSize property.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Rail Community
