Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Parts canfaceoffset
2 REPLIES 2
258 Views, 2 Replies
Parts canfaceoffset
After splitting a part, the canfaceoffset() returns false on the faces where the split occured. However, through the UI, when 'show shape handles' is checked those faces can be offsetted. I am wondering if this is the expected API behavior. If so is there a workaround within the API?
Thank you,
Nelson
2 REPLIES 2
jeremytammik
Dear Nelson,
Thank you for your query.
What version of Revit are you observing this in, please?
I see an issue in the database that looks similar to your report: REVIT-6944 [Parts offset from API return False where should return True].
It was submitted in April 2013 and is marked as resolved and submitted, son I would expect it not to happen any longer in Revit 2015.
Can you please try that out?
Thank you!
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
in reply to: jeremytammik
I was working on the 2014 platform. I tested it in 2015 and everything seems to be working.
Thank you for the quick reply,
Nelson
Rail Community
