I have a set of pipes for example as follows:
1.---------------------------------------------------------------------------------------------------------------
2. -------------------------------------------------------------------------------------------
3.-------------------------------------------------------------------------------------------------------------
4. -------------------------------------------------------------------------------------------------------------------------------------------
Now I want to loop all these pipes in pairs [1-2,2-3,3-4] and then check whose diameter is greater in the pair and according to the greater daimeter found move the second pipe in the pair up or down so that distance between them is the greater diameter found between this pair.
Thanks & Regards
So which part of the workflow are you having trouble? Are those Revit MEP Pipes? Are you using MEP System with connectors?
