As we get closer to releasing Revit 2015 to the masses I'd like to clean up our families and project files to be free of Non-Standard Subcategories. For example, I loaded every one of our families into a OOTB Imperial template and then exported the list of categories and subcategoriesfrom that project. There are all kinds of discrepencanies, like, "Hidden", "hidden", "Hidden Line", and the OOTB "Hidden Lines" subcategories.
Is it possible to merge those subcategories into the "Hidden Lines" subcategory within the project? Then I'll rexport them back to families files.
I thought about trying to merge the subcategories within each family, but the problem is, the family can show no subcategories, but could still create subcategories when loaded if there is a sub-family that had that subcategory. By changing it in the project, then exporting, it permantely deletes those invisible subcategories. This is my prefered method because it would allow me to keep the families in the same folder structure. Is this method possible?
Thanks!
Solved by R.van.den.Bor. Go to Solution.
Are you able to do this using the UI? If you are not able to do it using the UI, then it will not be possible with the API.
Best Regards
Gopinath
I was hoping that wasn't the solution, but it looks like I'll need a routine that will open each one, and it's nested families, and change their subcategories to our standards. It's just a bit more complicated because of things like Filled Regions, where I'll have to edit their subcategory by sketch.
Thanks for the replies!
