Hey Guys,
What is the class (or the closer one) in Revit API that mimics AutoCAD LWPOLYLINE object i would like to
to excute a boolean operations on closed boundaries to find:
if one is inside other?
are they crossing each other?
or are they totally apart?
thanks in advance
Moshe
Remy,
As far as i know/understand a BoundingBox is rectangle (4 straight lines at 90 degrees)
Am i right?
as i noted i want to execute booleans on real boundary of any polygon which can have arcs
Moshe
That's correct, a boundingbox is a rectangle. What you want depends on the element you want to use. For instance, walls have edges and faces of which you can ask for the points.
the element i want to check for boolean operation is Area Boundary
i know i can take Area.GetBVopundarySegments(); and do the coding my self
but i thought Revit API has it like AutoCAD API has it for LWPOLYLINE
you can retrieve objects such as CurveLoop and CurveLoopArray from the faces found in a GeometryObject, but these are just containers and do not provide functionality such as boolean operations.
There is an API for boolean operations on solids, but for 2d polygons you will need to either code your own or bolt in a 3rd party library.
I've taken the first option and coded my own specialised classes for slicing arbitrary polygons with singular planes and performing point-polygon and polygon-polygon inclusion checks, but I'll probably convert to a 3rd party library at some point in the future as my needs grow.
Jeremy has a great blog entry on this very subject: http://thebuildingcoder.typepad.com/blog/2013/09/boolean-operations-for-2d-polygons.html
