Hi All,
I'm very new to revit API's but have used revit for about 4 -5 years or so.
What i'm curious about is how can i create a Family Type parameter similar to the Keynote or Assembly code parameter where by selecting the eclipse(three dots) it brings you to a specific file where you can return a value to the parameter value field.
Is this possible with the API or do I need to try a different solution?
Any Ideas?
Thanks Paul.
