Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Insert Revision Cloud
1 REPLY 1
drdanielfc
429 Views, 1 Reply
How can I insert a revision cloud programatically using the Revit API?
I am using C# but if you'd prefer to post in a different language, I can easily translate.
Tags (2)
1 REPLY 1
Joe.Ye
in reply to: drdanielfc
I attached a file that shows how to create a revision, and a revision cloud.
This command cannot run as it requires some forms. You can get the idea form the command.
Hope this helps.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Rail Community
