I’ve been using some updaters that use the IUpdater interface in some of my addins. I don’t have any problems with the updaters themselves really, it’s just that I implemented one a while ago without setting it to "optional" and so a file I was working on was saved with “non-optional” updater data in it. Now when somebody without the updater loads the file, as expected they get the “Missing Third-Party Updater” message. I know in the future to set any updaters as optional, but is there any way to remove/suppress the message on this older file?
I know that this message is merely a warning, and I’ve even written code to account for all changes that somebody’s made to the file without the updater. But the issue is that I’m working with some people who get spooked very easily and won’t touch this file when this message pops up, even when I’ve explicitly told them it’s alright just to hit “Continue working with the file.” or “Do not warn about this updater again and continue working with the file.”. Basically I need to remove the data from the model that informs it that it was once modified by a non-optional updater; even changing the updater to optional in my .dll and loading it into the file doesn't overwrite the model knowing that it was onced modified non-optionally. Hope this all makes sense.
Travis
Hi there,
I think you could use the Failure API for that:
http://thebuildingcoder.typepad.com/blog/2010/04/failure-api.html
I hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Dear Travis,
If you really seriously just want to suppress the message and nothing else, I have the absolute killer for you: my dialogue clicker:
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
Here is a usage example:
http://thebuildingcoder.typepad.com/blog/2012/01/synchronize-with-central.html
Last resort, though, I would say.
