Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to create a dialog using VB.NET?
5 REPLIES 5
jan
780 Views, 5 Replies
Using VB.NET, I need to add a dialog in Revit, but it seems to be a bit problematic.
I have tried to study a C # project created in REX expansion wizard, but I can not figure out how exactly the dialogue is implemented and embedded in Revit.
I can find many examples of the use of a task-dialogue, but that is not the kind of dialogue that I need.
What I need is a dialog box that contains some text boxes, combo boxes, etc. and blends nicely into the Revit user interface.
Does anyone have an example of that?
regards
Jan grenov
5 REPLIES 5
augusto.goncalves
in reply to: jan
To use Forms inside Revit you just need to create a 'classic' WinForm, and there are several samples of that on the web.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
jan
in reply to: augusto.goncalves
Thanks Augusto
I guess that I might have posted my question unpecisely. My fault. Sorry!
I will try to be a little more precise ..
  1. I have done the "Hello world" a long! time ago, and I know how to make a form in VB!
  2. I just thought that there migth be some elegant way of implementing forms in Revit so that I do not need to check the WinForms Topmost property.
    Similar as in AutoCAD:
    Dim dia As New someDialog(FormOpener.AutoCAD)
    Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(dia)
I want my form to be hidden when the Revit window is hidden. Not to show as if it was an an independant application. Must I somehow refer to the Revit hwnd or have I missed something basic?
Regards
Jan Grenov
PhillipM
in reply to: jan
Ok.
You want to show a dockable dialog that belongs to Revit.  Two options.
  1. Revit 2015 - & 2014.  Using the dockableDialog interface.  There is a good example of that working in the SDK called DocakableDialogs.  You will actually be using WPF forms for this unless you host a Win Form inside of a WPF form.
  2. Pre Revit 2014.  AS you suggest using Revit hwnd and there is examples of that on Jeremy's Building COder blog i'm pretty sure.
Regards
Phillip
jeremy_tammik
in reply to: jan
Dear Jan,
Yes, you were indeed imprecise  🙂
Yet, rejoice!
Salvation is nigh!
Google for "JtWindowHandle":
http://lmgtfy.com/?q=revit+api+JtWindowHandle
Cheers,
Jeremy
p.s. Phillip's answer is very valuable. If you can use a hosted palette, that is much more elegant and integrated. Thank you, Phillip!
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
jan
in reply to: jeremy_tammik
Thanks Guys 🙂
I think that I will look a little more into those "hosted palettes". Sounds as an interesting solution.
Regards
Jan
Autodesk DevCon in Munich May 28-29th
Rail Community
