Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to change parameter names?
7 REPLIES 7
Message 1 of 8
4714 Views, 7 Replies
I have to retrieve some family symbols belonging to the same category. But different symbols have different parameter names defined by users.
How can I change the instance/type parameter (user defined) names?
Thanks.
Tags (1)
7 REPLIES 7
Message 2 of 8
jeremytammik
Dear Kukuzry,
Does the family editor allow you to change the names?
Best regards,
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
in reply to: jeremytammik
Yes, it allows.but how can I change it through API?
Message 4 of 8
jeremytammik
Aha. If it is possible manually, there may be a programmatic way also. You probably have to open the family to edit using the EditFamily method, navigate to the type and family parameter to modify and use the FamilyManager.RenameParameter method on it.
Jeremy Tammik
The Building Coder
Message 5 of 8
good idea, thanks
Message 6 of 8
R.van.den.Bor
For completeness sake : This won't work for shared parameters, they can't be renamed (not even by hand).
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
Message 7 of 8
For complete completeness sake: yes and no...
http://thebuildingcoder.typepad.com/blog/2013/11/translated-shared-parameter-guid-consolidation.html
http://thebuildingcoder.typepad.com/blog/2013/12/devlab-munich.html > Multi-language Shared Parameters
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 8
Okay, thanks for pointing this out Jeremy. This is a workaround I will surely try. I was always under the impression shared parameters where "off limits". I once crashed my revit muddling with the sahred parameter file (I clearly says "Don't edit manualy" and I learned the hard way they where not kidding). But apperently jasper found a work-around. Very interesting 🙂
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Rail Community
