Revit API
Active Contributor
Message 1 of 4 (446 Views)
How to Set Line Pattern in Line Style
446 Views, 3 Replies
12-10-2012 05:42 PM
I'm creating new line styles in Revit MEP 2013 through the API in VB.Net, and I've almost got everything figured out... except setting the line pattern. There doesn't seem to be a way to do this one, last step. Any ideas?
Here's what I have so far:
PublicFunction LoadStyle(ByVal n AsInteger) AsBoolean
Dim lineCat As Categories = m_RvtDoc.Settings.Categories
ForEach objCategory As Category In lineCat
If objCategory.Name = "Lines"Then
If objCategory.CanAddSubcategory = TrueThen
Try
Dim cat As Category = lineCat.NewSubcategory(objCategory, MEP(n, 6))
'set color
If MEP(n, 7) <> ""Then
Dim r, g, b AsInteger
                            r = MEP(n, 7)
                            g = MEP(n, 8)
                            b = MEP(n, 9)
Dim c As Autodesk.Revit.DB.Color = New Autodesk.Revit.DB.Color(r, g, b)
                            cat.LineColor = c
EndIf
'set lineweight
If MEP(n, 11) <> ""Then
                            cat.SetLineWeight(
CInt(MEP(n, 11)), GraphicsStyleType.Projection)
EndIf
'set line pattern
If MEP(n, 10) <> ""Then
'cat.LinePatternId = GetElementByName(GetType(LinePatternElement), MEP(n, 10))
EndIf
Catch
                        MsgBox(
"Line style " & MEP(n, 6) & " already exists.", MsgBoxStyle.Information, "Load Systems Error")
EndTry
Exit For
Else
                    MsgBox(
"Can't add line style.")
Exit For
EndIf
EndIf
Next
EndFunction
ADN Support Specialist
Message 2 of 4 (412 Views)
Re: How to Set Line Pattern in Line Style
12-19-2012 01:51 AM in reply to: dhorger
Revit didn't expose the API to change category's line pattern. Revit engineering team already knew this request. Hope this will come not long.
Joe Ye
Developer Technical Services
Autodesk Developer Network
Active Contributor
Message 3 of 4 (407 Views)
12-19-2012 10:58 AM in reply to: Joe.Ye
Thanks for the response, Joe. Would it be possible to check to see if it's exposed in Revit 2014? And are there any workarounds? This is very important for my project.
Dave Horger
Interface Engineering, Inc.
Message 4 of 4 (398 Views)
12-19-2012 10:38 PM in reply to: dhorger
Thanks for your comments on the API wish. I passed on your comments on this request to the engineering team.
Joe Ye
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
