I want to put a half scale on our drawing sheets and was wondering if anyone with macro/plug-in knowledge has done this before. We currently work with A1 size sheets but often print/pdf A3s before construction issue drawings. I want to show the A1 scale (eg. 1:100) as well as an A3 half scale (eg. 1:200) in the titleblock without having to manually put in text as this can cause inconsistencies.
Can anyone help with this?
Revit API cannot change the scale value shown in the titleblock. The scale value is decided by the scale of the view port in the sheet.
I am also facing a similar issue would it be possible to create a Shared Parameter which would alway set it self to half of view scale
