Revit API
Active Member
ivo.zagar
Message 1 of 3 (192 Views)
FilledRegion.Create returning Boundaries are self-intersecting.
192 Views, 2 Replies
04-01-2013 05:28 PM
I have simple code where I want to create FilledRegion. Whatever I do I get back: Boundaries are self-intersecting.
Here's my code:
IList<RDB.CurveLoop> boundaries = new List<RDB.CurveLoop>();
RDB.CurveLoop curve = CreateCurve(doc, new RDB.XYZ(0, 0, 0), new RDB.XYZ(0, 10, 0));
boundaries.Add(curve);
RDB.CurveLoop curve2 = CreateCurve(doc, new RDB.XYZ(0, 10, 0), new RDB.XYZ(10, 10, 0));
boundaries.Add(curve2);
RDB.CurveLoop curve3 = CreateCurve(doc, new RDB.XYZ(10, 10, 0), new RDB.XYZ(0, 0, 0));
boundaries.Add(curve3);
CreateFilledRegion(doc, boundaries);
And here are two external functions:
private RDB.CurveLoop CreateCurve(RDB.Document doc, RDB.XYZ start, RDB.XYZ end)
    RDB.Line line = doc.Application.Create.NewLine(start, end, true);
    RDB.CurveLoop curve = new RDB.CurveLoop();
    curve.Append(line);
    XLIB.Geometry.CreateDetailLine(doc, start, end);
    return curve;
private void CreateFilledRegion(RDB.Document doc, IList<RDB.CurveLoop> boundaries)
    RDB.Element t = XLIB.Selection.GetTypes(doc, typeof(RDB.FilledRegionType)).FirstOrDefault();
    RDB.FilledRegion.Create(doc, t.Id, doc.ActiveView.Id, boundaries);
Any thaugts?
Cheers,
Ivo
New Member
enonrick
Message 2 of 3 (158 Views)
Re: FilledRegion.Create returning Boundaries are self-intersecting.
04-02-2013 07:37 PM in reply to: ivo.zagar
this is my working code snippet:
newCurveLoop = new List<CurveLoop>();
curveLoop = new CurveLoop();
for (int i = 0; i < LineCount; i++)
.......... if ((LINE_TYPE)lineType == LINE_TYPE.LINEAR) curveLoop.Append(_document.Application.Create.NewLine(new XYZ(x1, y1, 0), new XYZ(x2, y2, 0), true)); else if ((LINE_TYPE)lineType == LINE_TYPE.ARC) curveLoop.Append(_document.Application.Create.NewArc(new XYZ(x1, y1, 0), radius, startRadian, endRadian, new XYZ(1, 0, 0), new XYZ(0, 1, 0))); } newCurveLoop.Add(curveLoop); FilledRegion.Create(_document, materialId, view.Id, newCurveLoop);
I'm just wondering, why are you recreated curveloop in each CreateCurve funtion,link this
just try it.
Active Member
ivo.zagar
Message 3 of 3 (141 Views)
04-04-2013 05:56 AM in reply to: ivo.zagar
Thanks, that was it: only one CurveLoop.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
