I want the value of Stringer Height and Stringer Thickness parameters of stair element, How can i do it using Revit API's 2012??
Solved by jeremytammik. Go to Solution.
Dear Shweta Agashe,
We already answered this question of yours in response to your ADN case 08298110 [Extraction of Stringer details of Stair Object using API 2012].
To share the result with others as well, I published the result on The Building Coder blog:
http://thebuildingcoder.typepad.com/blog/2013/04/migrating-a-built-in-category-and-other-things.html...
I hope this helps.
Best regards,
