Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Exporting to DWF
7 REPLIES 7
Message 1 of 8
russ.green
1106 Views, 7 Replies
Exporting to DWF
I'm having a little trouble exporting sheets to DWF.
It wall works except if the sheet being exported does not have the print setup zoon set to 100% before running my addin the sheets  will print to DWF scaled to fit or whatever scale factor it set to. I'm therefor trying to make sure the print zoom scale is set to 100% in my code before calling the export dwf method but its not changing the zoom.
This is my code...
Dim ptManager As PrintManager = uidoc.Document.PrintManager
Dim ptSetup As PrintSetup = ptManager.PrintSetup
Dim ptParameters As PrintParameters = ptSetup.CurrentPrintSetting.PrintParameters
ptParameters.ZoomType = ZoomType.Zoom
ptParameters.Zoom = 100
Try
    ptManager.ViewSheetSetting.Save()
Catch ex As Exception
End Try
Try
   ptManager.PrintSetup.Save()
End Try
uidoc.Document.Export(sbIssuePath.ToString, sbFile.ToString, views, DWFExpOpt)
Can someone please point me in the right direction?
Russ Green
7 REPLIES 7
Message 2 of 8
saikat
in reply to: russ.green
Hi Russ
The PrintManager class is used to configure for print settings and not for DWF export. Using this class, we can setup a printer and accordingly get access to available paper sizes, zoom level etc.
For DWF Export, as you might have noticed from Revit UI, it uses the Revit DWF Exporter and its settings (including Sheet sizes, and other settings, etc) are typically controlled by the DWFExportOptions. Unfortunately, zoom is not part of this as yet. The Development team is aware of how useful this would be and I hope we get to see this ability to set Zoom programmatically for DWF export soon too.
cheers
Saikat Bhattacharya
Senior Manager - Technology Consulting
Message 3 of 8
russ.green
thanks.
I've got it working now but yes it would be so much cleaner to have zoom as part of the DWF Export Options.
A PDF Export function would be a bit useful as well Smiley Happy
Russ
Russ Green
Message 4 of 8
saikat
Glad to know that you got the DWF Export piece to work. Thanks for letting me know.
Regarding PDF exports, if you have a PDF Writer Driver installed, we can use the Print Manager API itself and set this driver and export to PDFs.
Hope this helps
Saikat Bhattacharya
Message 5 of 8
russ.green
yeah well seems to be quite hit and miss printing a sheet to PDF.  Trying to print the active view (which would have just been exported to DWG and DWF and sometime the app doesn't think there is a view selected but I can't see why as when I debug and step thjough I always have a view selected.
i'll keep trying
Russ Green
Message 6 of 8
petersen200
Hi Russ Green.
I'm making a DWF exporter, I have a problem to controls color option and the Zoom function.
It sounds like you've solved it, hope you could help to explain me how you solved it.
Thank you for your time.
Asger Petersen
Message 7 of 8
russ.green
in reply to: petersen200
Start a transaction.
Create and set your print manager / setup.
Then export the DWF.
You have to set your print setup first.
            trans.Start()
            pMgr = thisdoc.PrintManager
            pMgr.PrintToFile = True
            Dim ptSetup As PrintSetup = pMgr.PrintSetup
            ptParameters.PaperPlacement = PaperPlacementType.Center
            ptParameters.ColorDepth = CType(Me.cboDWFColors.SelectedItem, ColorDepthType)
            ptParameters.ViewLinksinBlue = Me.chkDWFViewLinksInBlue.Checked
            ptParameters.HideReforWorkPlanes = Me.chkDWFHideRefWorkPlanes.Checked
            ptParameters.HideUnreferencedViewTags = Me.chkDWFHideUnreferenceViewTags.Checked
            ptParameters.HideCropBoundaries = Me.chkDWFHideCropBoundaries.Checked
            ptParameters.HideScopeBoxes = Me.chkDWFHideScopeBox.Checked
            ptParameters.HiddenLineViews = HiddenLineViewsType.VectorProcessing
            ptParameters.RasterQuality = CType(Me.cboDWFRasterQuality.SelectedItem, RasterQualityType)
            Try
                pMgr.ViewSheetSetting.SaveAs("transmittal")
                'do nothing and move on
            End Try
            Try
                pMgr.PrintSetup.SaveAs("transmittal")
            End Try
            Dim DWFExpOpt As DWFExportOptions
            DWFExpOpt = New DWFExportOptions
            With DWFExpOpt
                .ImageFormat = DWFImageFormat.Lossless
                If Me.rdoDWFDefault.Checked = True Then .ImageQuality = DWFImageQuality.Default
                If Me.rdoDWFLow.Checked = True Then .ImageQuality = DWFImageQuality.Low
                If Me.rdoDWFMedium.Checked = True Then .ImageQuality = DWFImageQuality.Medium
                If Me.rdoDWFHigh.Checked = True Then .ImageQuality = DWFImageQuality.High
                .ExportingAreas = chkDWFExportAreas.Checked
                .ExportObjectData = chkDWFObjectData.Checked
                .PaperFormat = sheetsize
            End With
            doc.Export(sIssuePath.ToString, ExportFileName, views, DWFExpOpt)
            Try
                pMgr.ViewSheetSetting.Delete()
            End Try
            Try
                pMgr.PrintSetup.Delete()
            End Try
Russ Green
Message 8 of 8
rodrigohbm
Hello
there any way to apply the above code without form is this in codio and then perform the export
regards
Autodesk DevCon in Munich May 28-29th
Rail Community
