Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Export Sections from families without accessing it .
1 REPLY 1
arh.rotaru
195 Views, 1 Reply
Hello everyone.
I am trying to write a plugin who export DWG every sections from certain families that are in the project. I am quite new in this domain and I am doing now the first plugin tutorial. Can you recommend me a starting point? What should I search? Is there something similar with what I want to obtain?
Best regards.
1 REPLY 1
R.van.den.Bor
in reply to: arh.rotaru
Hello arh,
I don't know how new you are in this domain 🙂 but I guess you have downloaded the revit api guide already.
In most cases I find google is my best friend. Just type in "revit api dwg export" and you'll find several topics. But in advance I find myself searching the building coder pages a lot.So here are a few suggestions:
http://thebuildingcoder.typepad.com/blog/2010/09/autocad-2010-dwg-export.html
http://thebuildingcoder.typepad.com/blog/2009/08/dwg-export-filename.html
Good luck with your plugin,
Remy.
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
Rail Community
