I am trying to create a foundation wall to go along with a newly created Wall, but the Create.NewFoundationWall is throwing this exception:
SEHException was caught
External component has thrown an exception.
Here is my code:
private void CreateFooting(Wall wall) { var coll = new FilteredElementCollector(Doc); ContFootingType type = coll.OfClass(typeof(ContFootingType)).Cast<ContFootingType>().First(); Doc.Create.NewFoundationWall(type, wall); // Throws SEHException }
Solved by jeremytammik. Go to Solution.
Have you ran with the debugger and checked that neither of the parameters are carbage?
Also you could provide little bit more accurate information about the thrown exception.
The exception message:
Message: "External component has thrown an exception."
ErrorCode: -2147467259
Source: RevitAPI
That is all the information provided by the exception, and the inner exception is null.
I believe my input parameters are not garbage, but here are copies of each from the Watch window:
ContFootingType (in Watch window):
- type {Autodesk.Revit.DB.ContFootingType} Autodesk.Revit.DB.ContFootingType - base {Autodesk.Revit.DB.ContFootingType} Autodesk.Revit.DB.HostObjAttributes {Autodesk.Revit.DB.ContFootingType} - base {Autodesk.Revit.DB.ContFootingType} Autodesk.Revit.DB.ElementType {Autodesk.Revit.DB.ContFootingType} - base {Autodesk.Revit.DB.ContFootingType} Autodesk.Revit.DB.Element {Autodesk.Revit.DB.ContFootingType} + AssemblyInstanceId {-1} Autodesk.Revit.DB.ElementId + Category {Autodesk.Revit.DB.Category} Autodesk.Revit.DB.Category DesignOption null Autodesk.Revit.DB.DesignOption + Document {Autodesk.Revit.DB.Document} Autodesk.Revit.DB.Document Group null Autodesk.Revit.DB.Group + Id {74960} Autodesk.Revit.DB.ElementId Level null Autodesk.Revit.DB.Level Location null Autodesk.Revit.DB.Location + Materials {Autodesk.Revit.DB.MaterialSet} Autodesk.Revit.DB.MaterialSet Name "Bearing Footing - 900 x 300" string ObjectType null Autodesk.Revit.DB.ElementType + OwnerViewId {-1} Autodesk.Revit.DB.ElementId + Parameters {Autodesk.Revit.DB.ParameterSet} Autodesk.Revit.DB.ParameterSet + ParametersMap {Autodesk.Revit.DB.ParameterMap} Autodesk.Revit.DB.ParameterMap PhaseCreated null Autodesk.Revit.DB.Phase PhaseDemolished null Autodesk.Revit.DB.Phase Pinned false bool + SimilarObjectTypes {Autodesk.Revit.DB.ElementSet} Autodesk.Revit.DB.ElementSet UniqueId "5f508b89-6196-4580-8385-8276203b8fd3-000124d0" string ViewSpecific false bool + WorksetId {0} Autodesk.Revit.DB.WorksetId + Non-Public members
Wall instance (in Watch window):
- wall {Autodesk.Revit.DB.Wall} Autodesk.Revit.DB.Wall + base {Autodesk.Revit.DB.Wall} Autodesk.Revit.DB.HostObject {Autodesk.Revit.DB.Wall} CurtainGrid null Autodesk.Revit.DB.CurtainGrid Flipped true bool + Orientation {(0.000000000, 1.000000000, 0.000000000)} Autodesk.Revit.DB.XYZ StructuralUsage Bearing Autodesk.Revit.DB.Structure.StructuralWallUsage - WallType {Autodesk.Revit.DB.WallType} Autodesk.Revit.DB.WallType - base {Autodesk.Revit.DB.WallType} Autodesk.Revit.DB.HostObjAttributes {Autodesk.Revit.DB.WallType} - base {Autodesk.Revit.DB.WallType} Autodesk.Revit.DB.ElementType {Autodesk.Revit.DB.WallType} - base {Autodesk.Revit.DB.WallType} Autodesk.Revit.DB.Element {Autodesk.Revit.DB.WallType} + AssemblyInstanceId {-1} Autodesk.Revit.DB.ElementId + Category {Autodesk.Revit.DB.Category} Autodesk.Revit.DB.Category DesignOption null Autodesk.Revit.DB.DesignOption + Document {Autodesk.Revit.DB.Document} Autodesk.Revit.DB.Document Group null Autodesk.Revit.DB.Group + Id {1060} Autodesk.Revit.DB.ElementId Level null Autodesk.Revit.DB.Level Location null Autodesk.Revit.DB.Location + Materials {Autodesk.Revit.DB.MaterialSet} Autodesk.Revit.DB.MaterialSet Name "Foundation - 300mm Concrete" string ObjectType null Autodesk.Revit.DB.ElementType + OwnerViewId {-1} Autodesk.Revit.DB.ElementId + Parameters {Autodesk.Revit.DB.ParameterSet} Autodesk.Revit.DB.ParameterSet + ParametersMap {Autodesk.Revit.DB.ParameterMap} Autodesk.Revit.DB.ParameterMap PhaseCreated null Autodesk.Revit.DB.Phase PhaseDemolished null Autodesk.Revit.DB.Phase Pinned false bool + SimilarObjectTypes {Autodesk.Revit.DB.ElementSet} Autodesk.Revit.DB.ElementSet UniqueId "74e46f31-7d48-47ee-9207-931708e57a52-00000424" string ViewSpecific false bool + WorksetId {0} Autodesk.Revit.DB.WorksetId + Non-Public members Kind Basic Autodesk.Revit.DB.WallKind Width 0.98425196850393681 double Width 0.98425196850393681 double
I still have not solved this problem. Does anyone know if there are certain requirements on the wall object that I am passing in as a parameter?
I really have no clue why I am getting this exception, and the error message gives no clue whatsoever as to the real nature of the problem.
Dear Jordanmarr,
I am answering this rather belatedly, since I just saw the same issue raised for the Revit 2013 API in this thread:
http://forums.autodesk.com/t5/Revit-API/Can-t-create-wall-foundation/m-p/4896020
Here is the answer that I provided there:
I am sorry to inform you that there was an issue with the NewFoundationWall method in Revit 2013.
It has been fixed in Revit 2014.
I found this information searching through my old ADN issues and encountering case 07700489 [Error when creating a new foundation wall] and SPR #230113 [NewFoundationWall does not work] that I explored back in October 2012.
Sorry for the bad news for Revit 2013, and happy to let you know it should work fine in Revit 2014.
Best regards,
Jeremy
