Show only
Search instead for
Thank you for your reply. I also, searched the entire adn, helpdesk and helps, still was not able to find one. After your reply only, i confirmed that there is no Support for Switching Documents and Detect Document Switch.
Maybe you can consider to use ViewActivate events: because Document switch will raise ViewActivate events, for example we can get Document handler from ViewActivatingEventArgs --> ViewActivatingEventArgs.CurrentActiveView.Document?
