My company has Views grouped via a discipline then subset along with family and type (Please see Example A.) so it was a bit of surprised when I went into the AllViews Sample and it listed much differently than what the view originally shown (see Example B.) versus what AllViews Sample had showed (see Example C) until I took off the formatting.
So in my quest to create a plugin that mirrors the Project Browser - how may I go into the Revit API to determine what the grouping, sorting settings are? Then once that is determined what is the best way to take the listing of all the views and then apply that via a tree view? I think the closest sample that can get me started is Revit 2014 SDK - Samples - All Views - but there doesn't seem to be anything on the formatting of the view structure within that code sample.
Sorry I cannot help. It seems like you would need to be able to get to the Browser object and its filter settings. Maybe the reason for your idea is mainly to provide flexibility and quick convenience not present in the Browser, but if you had access to the Browser object and its filter settings then why not control the Browser as you need it with new settings on the fly instead of using existing settings to build a new Browser. Looking at your last image and assuming it is the early fleshing out of a sheet creation tool I wonder how you plan to get around the manual placement tasks required for sheet composition and also the book keeping task of which views are already used. The standard Browser has all of those capabilities built into it. It just needs a convenient way to drive it for specific tasks, like the one I am thinking you are looking for. Your customization would not look like a new Browser. Instead it would be sets of controls that instantly manipulate how the Revit browser organizes the views needed for sheet composition in addition to having some task controls and settings.
Dear Stephen,
I am not aware of any functionality at all provided by the Revit API to determine any special ordering of views.
You would have to use other generic properties and relationships to set up the ordering you desire.
I cannot say whether the API provides all the information required to mirror the constellation displayed in the Project Browser.
I hope this help.
Best regards,
Jeremy
Word of warning here:
Replicating the current Revit Project Browser is a huge development project. I know cause I've been there. It is possible, but I thought it may take a month? Well it took 6 lol.
For a video of what I achived click on this link
Cheers
Phillip
Dear Phillip,
Thank you for your valuable advice and the nice video. Very impressive indeed.
Cheers,
Jeremy
aksaks-
I'm in agreement with everything you've said except up to the point - ....
"this might be two datagridviews"
I'm perfectly fine with one datagrid view with selected checkboxes for each row that display the name of each view.
Probably a combo box above it to filter the types of views.... Floor Plan, 3D View, Building Section, Schedule, Panel Schedule,
Hit a button and it would go and create the new views based on what's in the datagrid.
Everything I want to do afterwards like a textbox for prefix and suffix - I can figure out.
I just need to get started with populating the datagrid with the views as a sample and a way to FILTER it.
That's the big thing for me - how do I filter it? Not even the AllViews Samples shows how I may do that.
PhillipM-
You've created a masterful, beautiful Revit Project Browser plugin - and has taken it way farther then I could have even dreamed of.
I just wanted somebody to update the current AllViews sample to at least have filtering so I could farther study on what I needed to do in this instance.
Is the filtering based on what's in the view name or another property for the view?
Thank you for your helpful replies thus far. I guess I should have said instead of formatting the Project Browser I should have used the word filter.
Well Done 🙂
The tricky part that I found was catching all the interactions within Revit that a user may do and have that automatically update my KC Browser. IE what happens if a user adds a view from teh ribbon or modifies a parameter of a view that needs to be instanatly reflected in the browser.
The other very trciky part is how you co ordinate all of this in a workshared environment.
Regards
Phillip
Hiya,
I wonder if you're overlooking a new Revit 2014 API feature? (See below - quote from RevitAPI.chm.)
I use this to get the selected views to create multiple duplicates.
You'd need your own button on the ribbon to run the macro from. Applying a keyboard shortcut would add to the accessibility.
Query the selection, apply the view.CanViewBeDuplicated(dupOpt) to the views, ask the user what type of duplication to use (if there's more than one), and you're there.
Cheers,
Matt
External commands now supported from Project Browser as active view
API commands and macros are now enabled when the Revit active view is the Project Browser.
Note that API commands are still disabled when the active view is the MEP system browser.
Hey 12360montes
Any chance you have some time to help me with just setting up the Objectlistview (treelistview) from sourceforge.com via WebEX?
I'm still getting a few errors (please note attachment) - did you have as many as well?
Those are only warnings about not having XML comments preceeding each public function.
You should be able to ignore them. If you need them, preceeding each, type "///" (without the quotes) in VS and you will get a XML template preceeding the function you can fill out. Then you should have no more warning.
Hope that helps.
... or switch off the Visual Studio XML documentation setting.
Cheers,
Jeremy
Not to duplicate this very important topic, the main issue is with schedules. Why on Earth we still cannot organize them?
Kiwi plug-in has this functionality (among many others), why not to release a free add-on or macros which only allows us to assign parameters to shedules and sort them in the browser? Just a third bookmark in the "browser organisation" function. Please, gurus, you are our last hope!
