Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Connector description
3 REPLIES 3
ollikat
445 Views, 3 Replies
Hi
In project document we have Connector class. This class does NOT have any property referring the "description" of the connector.
The description however exists within the connector, because it can be set inside the family document. This is because connector in family document is instance of ConnectorElement class.
Furthermore the Revit UI has access to this information from project document!!!
Now I'm asking if there are ANY change to access this information trough Revit API?? Opening the family document is out of question because there is no way to know which connector in project document refers to connector in family document.
I would really appreciate if someone has some tips regarding this...
3 REPLIES 3
jeremytammik
in reply to: ollikat
dear ollikat,
you are an ADN member, aren't you?
please submit a DevHelp Online query for this, and we can check.
thank you!
best regards
jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
The Building Coder
ollikat
in reply to: jeremytammik
Hi
Yes...correct. I updated an existing case (1270617) and added reference to this discussion.
Thanks...
jeremytammik
Dear Olli,
Great, thank you, I will update your existing case then.
Cheers, Jeremy.
Jeremy Tammik
Jeremy Tammik
The Building Coder
Rail Community
