Hi!
I've created a plugin with a preview object. When I'm changing the 3D viewdirection of the view, the "cube" in the top-right corner rotates accordingly, but my model in view is not. Can someone explain why?
Also are the fundamental views built into the API somewhere? (for example front view direction)
Thanks!
Solved by RevitDevR. Go to Solution.
