Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Change the level of an element
1 REPLY 1
FRFR1426
3290 Views, 1 Reply
How can I change the level of an element? Level property is read-only...
There is a trick or a hidden method somewhere?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Tags (1)
1 REPLY 1
Revitalizer
in reply to: FRFR1426
instead of setting the level *property*, you could try to set the level *parameter*.
Depending on the type and category of the element you want to modify, you could set the BuiltInParameter.FAMILY_LEVEL_PARAM (for FamilyInstances), for example.
Use RevitLookup to get the level parameters for other kinds of elements.
Level params usually are set with an ElementId:
http://thebuildingcoder.typepad.com/blog/2011/01/family-instance-missing-level-property.html
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Rail Community
