Hello!
Is it possible to programmatically change the category of FamilyInstace?
Solved by jeremytammik. Go to Solution.
No, I believe that is fixed by the family and connot be changed in the individual instance.
Cheers,
Jeremy
Thanks you for answer.
But I mean, is it possible to programmatically repeat the same actions as the user interface: Select object, click Edit in-place, click Family categories and parameters and select different category?
Yes, sure. Please note that you cannot manipulate in-place familes programmatically at all. If it is a standard family, however, you can use the Document.EditFamily method to open the family document for modification, and then reload it into the project again when you are done.
Cheers,
Jeremy
My pleasure entirely 🙂
