Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Calculated value
4 REPLIES 4
AlexanderSkibin
409 Views, 4 Replies
Calculated value
How to create calculated value in a schedule and add there an if...else statement?
May be I should use a new property IsCalculatedField?
Alexander.
4 REPLIES 4
Joe.Ye
in reply to: AlexanderSkibin
Hi, Do you want to add a new column to the schedule, and assign values by calculated value?
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
AlexanderSkibin
in reply to: Joe.Ye
I want to add a new calculated value and a new column to the schedule.
All that I know about calculated value is property IsCalculatedField, but it is read only.
As far as I know you cannot yet create calculated fields in schedules using the API.
If you already know the parameters that need to be calculated you could pre-build a minimal schedule manually in the template consisting of only the parameters and calculated fields required then use the API to duplicate it and add/remove/hide other fields and apply filters as required.
You could even make a 'SuperSchedule' packed full of parameters and many combinations of calculated fields, then duplicate and customise it on the fly as needed.
Hopefully access to calculated fields is available in the next release.
Autodesk DevCon in Munich May 28-29th
Rail Community
