Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Buttons in Revit Ribbon Panel
1 REPLY 1
mohammadarslan
420 Views, 1 Reply
I have created Ribbon Panel using C#. It has three Push Buttons. When a push button is clicked, it should display data , which is stored already in database.
Means, I have to make External Command behind that Push Button. But how will that external command will be able to fetch data from database ?
1 REPLY 1
The database must provide an API that the external command can make use of.
Jeremy Tammik
Developer Technical Services
The Building Coder
Rail Community
