Hi all!
Does anyone know, is it possible to retreive built-in parameter definitions (InternalDefinition) without having actual Parameter object(s)?
Document::ParameterBindings() returns only shared parameters etc. but no built-in parameters.
Solved by adam.nagy. Go to Solution.
Hi there,
Do you want to get the buil-in parameter definition to retrieve its name?
Then this should help:
http://thebuildingcoder.typepad.com/blog/2011/08/built-in-parameter-name-and-labelutils.html
Cheers,
Adam Nagy
Autodesk Developer Network
