Is there any Books or other Resources available from which help can be taken for making applications.
Solved by jeremytammik. Go to Solution.
Solved by Joe.Ye. Go to Solution.
Revit 2013 provide the online Revit Developer Guide. It is a good resource to get started and deep into Revit programming.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00006-API_Developer's_Guide
We provided the "My First Revit Plug-in" instruction for those who don't have any Revit programming skills.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16777469
In addition to that, ADN recorded the DevTV to get started with Revit programming. You can find them in this page.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
Hope this helps.
Los SDK de Revit API contienen variedad de ejemplos que puedes utilizar para avanzar en el desarollo de tus plugins. Al igual que diferentes foros donde puedes seguir mejorando tus conocimientos del API.
Si planeas empezar a realizar desarrollo de Plugins que utilizen el API es recomendado considerar volverte miembro de ADN (Autodesk Developer Network) donde tendras accesso a tanto los softwares como los SDK's y contaras con la oportunidad de preguntar dudas a una red de expertos en el tema en caso necesites ayuda.
http://adndevblog.typepad.com/aec/
Cualquier otra consulta no dudes en contactarnos.
Exitos,
two of those link already been remove would u please fix that .Thx~
Updated versions of all of the links provided by Joe are available from the overview of the Revit API getting started:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
