Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Books on Revit API
7 REPLIES 7
Message 1 of 8
5807 Views, 7 Replies
Books on Revit API
Is there any Books or other Resources available from which help can be taken for making applications.
Tags (1)
7 REPLIES 7
Message 2 of 8
Joe.Ye
Revit 2013 provide the online Revit Developer Guide. It is a good resource to get started and deep into Revit programming.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00006-API_Developer's_Guide
We provided the "My First Revit Plug-in" instruction for those who don't have any Revit programming skills.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16777469
In addition to that, ADN recorded the DevTV to get started with Revit programming. You can find them in this page.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
Hope this helps.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Thank you so much for your quick reply.
Message 4 of 8
wmespinosa
Que hay despues de mi primer plug-in?? mas ejemplos?
Message 5 of 8
R.van.den.Bor
in reply to: wmespinosa
Pruebe estos blogs
http://forums.autodesk.com/t5/Revit-API/Check-out-the-self-paced-guide-My-First-Plug-in/td-p/3032684
y
http://thebuildingcoder.typepad.com/blog/about-the-author.html # 5
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
Message 6 of 8
rosalesduquej
Los SDK de Revit API contienen variedad de ejemplos que puedes utilizar para avanzar en el desarollo de tus plugins. Al igual que diferentes foros donde puedes seguir mejorando tus conocimientos del API.
Si planeas empezar a realizar desarrollo de Plugins que utilizen el API es recomendado considerar volverte miembro de ADN (Autodesk Developer Network) donde tendras accesso a tanto los softwares como los SDK's y contaras con la oportunidad de preguntar dudas a una red de expertos en el tema en caso necesites ayuda.
http://adndevblog.typepad.com/aec/
Cualquier otra consulta no dudes en contactarnos.
Exitos,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Message 7 of 8
s26478626
in reply to: Joe.Ye
Message 8 of 8
jeremytammik
in reply to: s26478626
Updated versions of all of the links provided by Joe are available from the overview of the Revit API getting started:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Jeremy Tammik
Autodesk Developer Network, ADN Open
The Building Coder
Rail Community
