Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Adding fields to a schedule
3 REPLIES 3
2057 Views, 3 Replies
I cant find out how to add a filed to a schedule.
I try to create a schedule and if I use ScheduleFieldType.Instance Revit derives many different fields. Can I choose these fields?
Regards, Alexander
3 REPLIES 3
I believe you can use the ViewSchedule.Definition.AddField(ScheduleFieldType fieldType, ElementId parameterId) method to add a new field populated with a desired parameter once you know its ElementId which you can get from the ParameterSet of a FamilySymbol, FamilyInstance or similar element.
Thank you, I will try.
My solution is:
ElementId mark = new ElementId(BuiltInParameter.ALL_MODEL_MARK);
if (schedulableField.ParameterId == mark)
ScheduleField field = schedule.Definition.AddField(schedulableField );
Autodesk DevCon in Munich May 28-29th
Rail Community
