Add and Get Conduit Standard and their Sizes in Revit 2014
Dear All,
I am not able to Get and add Conduit Standard and their sizes in Revit Using C# code . Please help me to overcome this problem.
 Thanks in Advance.
jeremytammik
Dear manishsingh12jan,
Have you looked at the routing preferences?
http://lmgtfy.com/?q=revit+api+routing+preferences
Do they cover conduits as well?
Cheers, Jeremy.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Dear Jeremy,
Thanks a lot, I want to add and retrieve conduit size Same as We are using Pipe Segment class we able to add Pipe Sizes(MEP Size). I want to do same thing for Conduit. Please Suggest.
jeremytammik
Thank you for your clarification.
I discussed this issue with the development team, and there seems to be no access to this functionality right now. Sorry about that.
I raised a wish list item for you, REVIT-20769 [As an external developer, I need to read Conduit and Cable Tray Size settings, so I can use them in my add-ins], as this issue requires exploration and possibly a modification to our software. Please make a note of this number for future reference.
Thank you for your understanding and patience.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Samir_emam
If there is solution in revit api 2016
