Revit API
Active Member
Message 1 of 2 (157 Views)
Accessing text in lables of Template in a View
157 Views, 1 Replies
11-22-2012 06:17 AM
Hi.
I am having trouble reading text in labels of templates, I can read the lable name but I dont know how to get the text from it.
Here is the code Im using:
Dim collector AsNewFilteredElementCollector(ExtCmd.CachedUiApp.ActiveUIDocument.Document)
Dim collection AsICollection(OfElement) = collector.OfClass(GetType(ViewSheet)).ToElements()
ForEach element AsElementIn collection
If SKRTegund = element.Name.ToString Then
Dim planView AsViewSheet = Nothing
Dim views AsList(OfElement) = collector.OfClass(GetType(View)).ToElements
ForEach v AsViewIn views
If v.Name = SKRTegund Then
                        planView = v
Dim IDS AsIList(OfElementId) = planView.GetTemplateParameterIds
ForEach stre In IDS
If stre.IntegerValue > 0 Then
Dim Elllem AsElement = ExtCmd.CachedDoc.GetElement(stre)
                                MsgBox(Elllem.Name.ToString)
EndIf
Next
                        MsgBox(planView.Parameter(
BuiltInParameter.SHEET_CURRENT_REVISION).AsString)
BuiltInParameter.SHEET_CURRENT_REVISION_DATE).AsString)
BuiltInParameter.SHEET_CURRENT_REVISION_DESCRIPTION).AsString)
                        MsgBox(planView.SheetNumber.ToString)
                        MsgBox(planView.Name)
EndIf
Next
Best regards
Active Member
Message 2 of 2 (136 Views)
Re: Accessing text in lables of Template in a View
11-26-2012 01:59 AM in reply to: Dollih
Ok, found it.
It is stored in the View.Parameter :
planView.Parameter(Elllem.Name.ToString).AsString
Thanks anyway
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
