I have implemented a revit plugin as an external application (IExternalApplication).
After doing some processing, I want to automatically exit Revit. Is there a way to do that?
You can try send Alt+F4 keys to Revit...have you tried that? It will depend on the context...
http://thebuildingcoder.typepad.com/blog/2010/11/launching-a-revit-command.html
Thanks!
I found a solution using Process.Kill()... not sure if there are any gotchas.
