Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
32 Bit RevitAPIUI.dll on 64 Bit machine
1 REPLY 1
Aminius
568 Views, 1 Reply
Hi, got a bit of a stupid problem here...
My Revit 2015 Plugin needs three DLLs, RevitAPI, RevitAPIUI, and System.Data.SQLite.
My installation of Revit is the 64 Bit version, but I also want to build the Plugin for 32 Bit.
I have found 32-Bit-Versions for two of the DLLs in the directory where Revit was installed from, but not RevitAPIUI.dll.
Can you please tell me where I can get it?
1 REPLY 1
Aminius
in reply to: Aminius
Never mind, I only just found out that there is no 32-bit version of Revit 2015.
It didn't occur to me because the installer of the Design Suite is for both architectures and because the RevitAPI.dll actually exists for 32 bit. Whyever that is...
Autodesk DevCon in Munich May 28-29th
Rail Community
