Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
2D aspects of Gridlines
2 REPLIES 2
IAN~JAMES
695 Views, 2 Replies
I want to try and write a quick little add-in that will allow me to select a whole row of grids and flip the bubble to the other end of the gridline in the view.
I can access the GRID_BUBBLE_END_1 and GRID_BUBBLE_END_2 parameters but these are related to the Grid Type default settings and not the view specific 2D elements.
I have found myself having to do this manually many times, so as I learn the Revit API I thought that this would be a nice easy exercise to get me going.
I guess if this also falls into the same category of accessing the Elbow control, its handle element and the 2D extents
I have tried using the SNOOP tool on both the grid and the active view but can't find anything... surely this must be accessible via the API...???
Any help appreciated
Ian
2 REPLIES 2
Joe.Ye
in reply to: IAN~JAMES
Currently Revit didn't expose the API to control the visibility of the bubble for a grid instance. This is a known API request.
The workaround might be you create a new grid type, and let the grid type show the bubble in the other end.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
IAN~JAMES
in reply to: Joe.Ye
Thanks for the reply Joe...
Hopefully this will emerge in a new version soon...?
I'm not sure I'm keen on the idea of changing a grid type to fix the grids in just one view. This could potentially be screwing up other views in the process, but thanks for the suggestion :))
Kind Regards
Ian
Rail Community
