Autodesk Remote requires an Autodesk Subscription to run. If you have a paid-Subscription and want to connect two PCs, you can download the PC client here:
You'll need to install the PC client on two machines to connect them.
The iPad app (not required to share two PCs) will let you drive your PC from your iPad. You can get the iPad app from Apple's App Store.
when i try to log in on a computer it says my log in is not asscoiated to a subscription contract which it is
the ipad version works fine
DarrenP
Are you still having this issue on the PC?
If you are, you may have an issue with some cached data on the PC. Please follow these steps to remove cached data:
1) Exit Autodesk Remote
2) Open file explorer and go to (type this into the location window) %localappdata%\Autodesk\adRemote
3) Open the folder v0.2 and delete all contents
4) restart Autodesk Remote and log in.
nope it didn't work
same error message
the weird thing is the beta worked fine
DarrenP
yes i do
DarrenP
Version 1.0.4.1
DarrenP
Ok, let's review the items you checked, because this still looks like corrupted data.
Thank you.
ok i'll email the log.txt file
DarrenP
sent email
DarrenP
nope
its only available to subscrption customers
DarrenP
was this ever resolved? I am having the same issue. I received an email saying I can use it but when I log in I get the same error.
