Remote Forum (Read Only)
Welcome to Autodesk’s Remote Forums. Share your knowledge, ask questions, and explore popular Remote topics.
Install issues
3 REPLIES 3
mikenoe
734 Views, 3 Replies
Install issues
2 different laptops both with Win 7 Pro, 1 with a fresh OS install.  Attempts to install Autodesk Remote fails on both.  Both launch the install and get as far as vredist_x86, the install screen disappears with no other indication of anything.
Any ideas?
Mike
Tags (1)
3 REPLIES 3
pendean
in reply to: mikenoe
bad download?
Not logged in as full admin on the laptops?
asburyj
Sounds like it's failing to get past the VC++ pre requisite. Go ahead load the programs and features control panel and then uninstall any versions of Microsoft Visual C++ 2008 and 2010 and then re install them from the below links. Note if you have a 64 bit OS you need both the x86 and x64 installs. If you have a 32 bit OS you only need the x86 installs. Once this is done try installing remote again.
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5582
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=2092
Microsoft Visual C++ 2010 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=8328
Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=13523
Jeffry Asbury
phil
in reply to: asburyj
Had the same problems. Followed the fix and it installed perfectly.
