Error on installation is
"There was an error installing the Autodesk Remote Service.
Service install Error Code: -500"
and installation aborts.
This is my home computer built specifically for running Inventor Ultimate Suite. I7, Win7 64 bit, nvidia GTX660 TI.
Remote connection loaded fine on my HP work system.
Used the same install executable on both machines.
Dave Gorjup
Dynamic Aviation
Hello Dave,
This -500 error means "WebCL installer timed out.". This indicates a permissions issue or there is a security or antivirus software blocking the install. Please ensure you are installing with an administrator account and your antivirus is disabled. You may also wish to disable UAC (http://windows.microsoft.com/en-us/windows7/turn-user-account-control-on-or-off)
Hi I have the same problem. Same error. Virus Scan has been disabled and UAC set to never.
Install will stick at
Execute: "c:\program files (x86)\autodesk\autodesk remote\servicesinstall.exe" /install
Can someone help?.
Most likely if it's not permissions that it would be an antivirus/antimalware software blocking the service creation
