Seriously.....This is released?
I can occasionally get it to work when I have 2 machines on the same local network. Forget about using it when I'm out of the office.
I installed this and tested it on my local network. It worked after rebooting each machine several times so I went off to customer meeting. Complete failure. Since then I've installed the updates and managed to get it to connect perhaps 1 out of 10 tries on my local network.
I'm using this so I can get to my powerful desktop with a very capable laptop. I'd consider buying an Ipad if the application would actually work on a repeatable basis.
The troubleshootong help on your website for this is a compkete joke. The application won't even tell you why it fails to connect.
I'm a consulting engineer aand it would be nice no to have to try to synchronize files on my laptop. However, I can't rely on this product to actually work when I need it.
Don Haulsee
Claremont, Va
Don, sorry to hear your having issues with connectivity. If you can provide some information and log files we can have one of our engineers take a look at the issues.
What OS are you using on the host and client machine?
Is either machine using a wireless network, if so which one?
Are you aware of any firewall or network packet inspecting software running on your network?
Zip the following files found at: %localappdata%\Autodesk\adRemote\v0.2 (open file explorer and copy that exact line in, it will take you to the folder)
- log.txt
- log_qos.txt
You can send these files to john.schmier@autodesk.com
Thank you.
